hwISession CaptureScreenToSize
Captures the current screen to an image file of the specified pixel resolution.
hwISession_handle CaptureScreenToSize type, filename, height, width, quality
HyperWorks Tcl Query
- type
 - The type of file. Options include: BMP, JPEG, TIFF, PNG, Clipboard
 - filename
 - The filename of the captured image.
 - width (Optional)
 - The width of the captured image in pixels (default in batch mode is 1024, otherwise default is value returned by hwISession::GetPageWidth).
 - height (Optional)
 - The height of the captured image in pixels (default in batch mode is 768, otherwise default is value returned by hwISession::GetPageHeight).
 - quality (Optional)
 - The level of quality or compression (default is 100). This is used only in JPEG type captures.
Examples
hwi GetSessionHandle sess;
sess CaptureScreenToSize png MyPicture.png 1600 1200;hwi GetSessionHandle sess;
sess CaptureScreenToSize jpeg MyPicture.jpg 1600 1200 60;hwi GetSessionHandle sess1
sess1 CaptureScreen "clipboard" E:\Scratch\CaptureScreenAPI_Test 1600 1200 100;Error
Success (0) or an error code.
