Midsurface
Extract the midsurface of thin solids, and review and edit midsurface plates.
View new features for HyperWorks 2022.3.
Define geometry preferences.
Explore the tools used to create geometry.
Learn about creating, editing, and extracting points and nodes.
Create and edit circles and rectangles with the Shapes tool.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Drag/Spin tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, or lines.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Use the Midsurfaces: Base Surfaces tool to specify a distance from the base surfaces of multiple solids that you wish to treat as if they were continuous. This will help generate separate-but-aligned midsurfaces during extraction.
Use the Midsurfaces: Automatic tool to extract the midsurface of sheet metal stampings, molded plastic parts with ribs, and other parts that have thickness clearly smaller than width and length.
Use the Midsurfaces: Edit Plates tool to review and edit midsurface plates.
Use the Midsurfaces: Pocket Imprint tool to imprint pockets, fillets, and other geometry features from the source geometry onto the midsurfaces.
Use the Ribs tool to create and modify simple ribs between two surfaces.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
The Use Parasolid option, found in multiple geometry tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
Setup an Optimization in HyperWorks.
ON THIS PAGE
ON THIS PAGE
