Shapes
Create and edit circles and rectangles with the Shapes tool.
View new features for HyperWorks 2022.3.
Define geometry preferences.
Explore the tools used to create geometry.
Learn about creating, editing, and extracting points and nodes.
Use the Circles tool to create circles for geometry construction, edit free circles, and create/toggle filled circles, for example, disk surfaces.
Use the Rectangles tool to create rectangles for geometry construction, edit free rectangles, and create/toggle filled rectangles.
Use the Arc Lines tool to create arcs for geometry construction, edit free arcs, and create/toggle filled arcs.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Detect, review, and manage geometric holes, fillets, flanges, and logos.
A surface represents the geometry associated with a physical part. A surface is a two-dimensional geometric entity that may be used in automatic mesh generation.
Solids are closed volume of surfaces that can take any shape. Solids are three-dimensional entities that can be used in automatic tetra and solid meshing.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Drag/Spin tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, or lines.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Extract the midsurface of thin solids, and review and edit midsurface plates.
Use the Ribs tool to create and modify simple ribs between two surfaces.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
The Use Parasolid option, found in multiple geometry tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
Setup an Optimization in HyperWorks.
ON THIS PAGE
ON THIS PAGE
