LD Card
This card specifies a distributed resistive, capacitive or inductive loading or a series combination of these loads for a segment(s).
On the Source/Load tab, in the Loads /
networks group, click the Load icon. From the drop-down list, click the
Distributed load (LD) icon.
![](../../../../../../images/feko/user_guide/editfeko_cards/dialog_ld.png)
Figure 1. The LD - Distributed load dialog.
Parameters:
- Define/replace a load at a segment
- Define a load with the following parameters.
- Remove all LD type loads previously defined
- This LD card does not define a load, but rather all previously defined LD loads are deleted. All the other input parameters of this card are ignored.
- Load name
- The name of the load.
- Label of segments to load
- All segments with this label are subjected to distributed loading.
- Resistance:
- The distributed resistance in .
- Inductance
- The distributed inductance in .
- Capacitance
- The distributed capacitance in .
The combined impedance of the segment with length is then
It should be noted that if the Capacitance (F/m) is left empty, it is treated as infinite, so that it does not contribute to the impedance.
The LD card may be combined with the LP, LS, LZ and the SK cards, but only one LD card may be used per label. If a second LD card is used, it replaces the values entered by the first card. This card has no significance for surface elements, even when these are assigned the same label.
