RA Card
This card defines an ideal receiving antenna that can be placed anywhere in the model.
On the Request tab, in the Solution requests
group, click the Receiving antenna
(RA) icon.
- Far field pattern: An ideal receiving antenna is described with an impressed radiation pattern.
- Near field aperture (single or multiple surfaces): An ideal receiving antenna is described with near field aperture(s).
- Spherical modes: A receiving antenna is described by
means of spherical modes with two options.
- Far field approximation: A receiving antenna is described by means of an impressed radiation pattern obtained internally from the spherical modes description.
- Spherical mode approximation: Spherical mode expansions of the fields radiated and received by antennas are related directly to compute the coupling between them.
