MD Card
This card exports the model and solution coefficients to a .sol file.
On the Request tab, in the Solution requests
group, click the Model decomposition
(MD) icon.
Figure 1. The MD - Options for model decomposition dialog.
A .sol file can be used to specify an impressed current source (AM card).
Parameters:
- Remove all previously defined model decomposition options
- All previously defined model decomposition options are removed.
- Model name
- The name of the model.
- Include all structures
- Model decomposition is done for all structures.
- Include structures with specified labels(s)
- Model decomposition is only done for structures with specified labels.
- Include structures with label range
- Model decomposition is only done for structures with a label in the range specified in the fields Start at label and End at label.
- Calculate solution coefficients in local coordinate system
- Select this option to calculate the model decomposition in a local coordinate system.
Define the local coordinate system by specifying the offset from the origin and the
rotation about the axis.
- Origin of offset coordinate
- Specify the Cartesian coordinates of the transformed origin. These values are affected by the scale factor of the SF card if used.
- Rotation about the axis
- The angle of rotation around the X axis, the angle of rotation around the Y axis and the angle of rotation around the Z axis in degrees.
