Assign mesh shadow to faces
Assign mesh shadow
To assign a Shadow Face to the faces:
| Stage | Action | |
| 1 | Activate the command Assign shadow to faces (see next block) | |
| → | An assignment box is opened. | |
| 2 |
                         Complete the assignment box:
| → | The shading has been assigned to the faces. | |
| 3 |
                         Continue the sequence of assignment:
                         Quit the sequence of assignment:
To activate the command Assign shadow to faces, which requires the selection of data, choose one of the methods in the following figure:
