Assign relaxation to lines / faces / volumes
Assigning a relaxation
To assign a Line, Face, Volume Relaxation to the corresponding geometric entities:
Stage Action
1 Activate the command Assign relaxation to lines / faces / volumes (see next block)
An assignment box is opened.
2
Complete the assignment box:
  • select the geometric entities on which the relaxation will be assigned
  • in the list proposed choose the relaxation
  • click on OK
The relaxation has been assigned to the selected geometric entities.
3
Continue the sequence of assignment:
  • return to stage 2
Quit the sequence of assignment:
  • click on Cancel
To activate the command Assign relaxation to lines / faces / volumes, requires the selection of data. Choose one of the methods in the following figure:
