Transform Elements
Use the Transformation Tool to translate, scale, reflect or rotate elements with multiple numbers of copies, including properties and loads, attached to them.
View new features for Engineering Solutions 2022.
Engineering Solutions is a modeling and visualization environment for NVH, Squeak and Rattle Director, Crash, CFD, and Aerospace using best-in-class solver technology.
Discover Engineering Solutions functionality with interactive tutorials.
Noise, Vibration and Harshness (NVH) is an important vehicle attribute that directly affects the customer experience.
Full vehicle NVH represents the most sophisticated form of NVH analysis, with many important benefits.
NVH Director offers the following features for modularized management of vehicle subsystems.
OptiStruct offers many features that reduce solution time and simulation complexities.
Change the angle of view on the model, lighting, or visibility and location of tab area items, among other options.
Provides tools to create and manage connectors.
Create or open a fatigue analysis setup process.
Setup a frequency response analysis with a series of step-by-step process templates.
Manage all of the IDs for the entities that you create, and define ID ranges for all of the entities in each Include file in relation to the full model in order to avoid ID duplication.
Access pre-defined macros packaged with the NVH solution and also user-defined macros.
Automate the grouping and display of model components through the entity set functionality using the Sets Browser.
Review details about Mass, Center of Gravity (Cog) and Inertia of your model.
Display/review and modify frequently used coordinate systems used in CAE analysis.
Setup a DDAM analysis for Abaqus, and use the Shock Spectra curves for a subsequent Response Spectum Analysis.
Provides functions to help you morph the shape of a finite element model.
Engineering Solutions Optimization technology is supported by OptiStruct.
Keep all of the default configuration options and store user preferences.
A big challenge in full vehicle NVH simulation is handling large size finite element models.
NVH analysis is a special form of physical analysis where the understanding of motion, energy and force transfer are the primary means of root cause identification and problem solving.
Use Squeak and Rattle Director tool to create evaluation lines, evaluate them and optimize the interfaces to eliminate squeak and rattle issues.
The Crash application offers a tailored environment in HyperWorks that efficiently steers the Crash CAE specialist in CAE model building, starting from CAD geometry and finishing with a runnable solver deck in Radioss, LS-DYNA and PAM-CRASH 2G.
HyperWorks offers high quality tools for CFD applications enabling the engineer to perform modeling, optimization and post-processing tasks efficiently.
Solver interfaces supported in Engineering Solutions.
Browsers supply a great deal of view-related functionality in Engineering Solutions by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Setup an Optimization in Engineering Solutions.
