- Auto-Contact
- Quickly and easily create one or more contact interfaces at once between several
parts of your model. This tool is only available in NVH when the OptiStruct and Nastran solvers are
loaded.
- Blocks
- Create and modify a block entity.
- Card Editor
- Select the entities that are viewed in the card image subpanel.
- Component Table
- Displays components and their associated attributes in an interactive table.
- Create Cards
- Displays a list of all available cards to create within the select user
profile.
- Count
- Obtain a count of all the entities in your database.
- DDAM
- Setup a DDAM analysis for Abaqus, and use the Shock
Spectra curves for a subsequent Response Spectum Analysis.
- Delete
- Delete data from a model database, preview and delete empty collectors and preview
and delete unused property collectors, material collectors, or curves.
- Edit
- Modify existing entities using the Entity Sets, Blocks, Tags and Titles Update
subpanels.
- Fatigue Process
- Create or open a fatigue analysis setup process.
- Frequency Response Process
- Set of process templates that use generic engineering data to automatically create
frequency response analysis loadcases and associated solver cards.
- ID-Manager
- Manage all of the IDs for the entities that you create, and define ID ranges for all
of the entities in each Include file in relation to the full model in order to avoid
ID duplication.
- Load Collector Table
- Review and edit OptiStruct load collectors.
- Loadsteps Browser
- Create, manage and display loadsteps (sub-cases) and the associated control
cards.
- Mass Details
- Review details about Mass, Center of Gravity (Cog) and Inertia of your model.
- Mass Trimming
- Create, define, and realize mass entities.
- Material Table
- Review and edit OptiStruct materials.
- Matrix Browser
- Explore HyperMesh and HyperView data entities and export the entities to external files
for further analysis.
- Model Checker
- Checks the model for errors and warnings. This tool is available in the Nastran and OptiStruct solvers in
NVH.
- NVH Macros
- Access pre-defined macros packaged with the NVH solution and also user defined
macros.
- Organize
- Reorganize your database by copying or moving data (entities) among collectors or
includes.
- Orientation Review
- Display/review and modify frequently used coordinate systems used in CAE analysis.
- Part Replacement
- Replace elements in an existing component/part (PSHELL) with new elements.
- Position
- Specify a new position for model entities.
- Pretension Manager
- Create and edit 1D and 3D pretension bolt loads and bolt sections for the OptiStruct solver. This tool is only available when the OptiStruct user profile is loaded.
- Property Table
- Displays properties and their associated attributes in an interactive table.
- Quick Access
- Quickly find and open the tools, panels and browsers that are available from the menu bar
pull-downs or from the Utility Browser.
- Reflect
- Reflect portions of a model about a plane, changing the selected portion into a
mirror image of itself.
- Renumber
- Renumber entities.
- Rotate
- Rotate entities around an axis in space.
- Scale
- Increase or decrease an entity’s dimensions.
- Set Browser
- Automate the grouping and display of model components through the entity set
functionality.
- Sets
- Create, update and review named sets of entities.
- Solver
- Run an external program from within Engineering Solutions or assign and run a solver on selected analysis decks.
- Summary Template
- Obtain a summary of component element counts or element properties of the current
model.
- Tags
- Assign names to entities.
- Titles
- Create, edit and move screen titles and entity tags.
- Transformation Tool
- Translate, scale, reflect or rotate elements with multiple numbers of copies
including properties and loads attached to them.
- Translate
- Move entities in a single specified direction.
