CSV-Comparison
The CSV comparison tool compares CAD/FE attributes against the CSV file column.
Supported attributes are Part name, PID, Part Number, Material Name, Thickness and File name. It has three options, compare, compare-update and create new XML.
  1. In the Comparison Browser, right-click and select CSV Comparison from the context menu.
  2. Click Compare.
    The File Selection window opens.
  3. A CSV file must be selected.
    Check will proceed.
    Generates reports showing the updated information in the Excel report, the same as comparison.
