Select a Range of Curves
  1. Select a curve name from the curve list.
  2. Drag the pointer to include the curves above or below the selected curve.
Or
  1. Select a curve from the list.
  2. Hold down the Shift key and select another curve from the list.
    The range of curve names between the first and second selections is highlighted.
