Integrated Diagnostics - Load Processing
Load the sensitivity and force results from an OptiStruct *.pch or Nastran *.pch file to calculate the vehicle responses.
File selection
Select the following file types:
Transfer Function
Select an OptiStruct or Nastran *.pch file, where the Transfer Function output is available.
Force
Select an OptiStruct or Nastran *.pch file where the Force output is available, then click Load.
Calculate and Export Forces
Calculates the vehicle response using the loaded transfer and forces files and exports the data into a PCH file. This PCH file gets loaded in the vehicle response tab.
TF tab
Review the TF options from this tab.
Subcase ID
Select a transfer function subcase from the drop-down menu.
TF Type
Select the transfer function type depending on the response type, pressure, velocity, acceleration.
Response ID
Select the grid ID of the response from the drop-down menu.
Component
Select the component of response grid ID from the drop-down menu.
Display Options
Customize the response plot, including scale, weighting, and the plot layout.
View TF
Once the result selection options are complete, select View TF to display the TF data.
Force tab
Review the forces from this tab.
Subcase ID
Subcase Label
Enter the subcase label.
Grid ID
Select the grid ID of the force output from the drop-down menu.
Component
Select the component of force grid ID from the drop-down menu.
Display Options
View Force
Coherence On/Off Parameters
Coherence Threshold Frequency
Specify the threshold frequency for coherence.
Wheelbase
The wheelbase to be used for the calculation; the value is taken from the result file.
Vehicle Speed
The vehicle speed to be used for the calculation; the value is taken from the result file.
