HM-3550: Morph Volume
This exercise shows how to smoothly change the shape of a B-pillar via morph volumes.
![](../../../images/hypermesh_morphing_b_pillar.png)
Open the Model File
In this step you will open the model file, body_side.hm.
Create Morph Volumes
In this step, you will create morph volumes.
Split Morph Volume
In this step you will split the morph volume.
Change the Profile, Method 1
In this step you will change the profile of the b-pillar using fixed value based method.
Change the Profile, Method 2
In this step you will change the profile using the interactive graphic manipulator base method.
