HM-3640: Interpolate Loads With Shapes
In this tutorial, you are given a temperature distribution at points defined by a cube (hexa element). You will use shapes to interpolate the temperatures to the tube lying inside the cube.
Shapes are one of the most versatile types of the morphing entities. Loads can be converted into shapes and vice versa. When you position shapes, they act on a volume equivalent to the initial volume, but at the new location. In this regard, shapes can be used to interpolate loads on a mesh given the loading at the boundaries of a volume.
Open the Model File
In this step you will open the model file, s_bend_tube.hm.
Convert Temperatures to Shapes
In this step, you will convert temperatures to shapes.
Translate the Shape
In this step, you will translate the shape.
Convert Shape Vectors to Temperature Loads
In this step, you will convert shape vectors to temperature loads.
Check the Result
In this step you will check the result.
