HM-3580: Morph About an Axis With Domains
In this tutorial, you will increase the radius of the spring coil.
![](../../../images/hypermesh_spring_wire_radius.png)
Load the Model File
In this step you will load the model file, spring.hm.
Change the Coil Radius
In this step you will change the coil radius.
