HM-3570: Alter Cross-Sections With Domains
In this tutorial, you will use domains and handles to increase the gauge thickness.
Open the Model File
In this step, you will open the model file, spring.hm.
Change Gauge Thickness
In this step you will change the gauge thickness.
