hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Retrieves the pointer to an element.
Retrieves the pointer to an element if it exists.
Retrieves a pointer to the first element stored in hmmodlib.
Retrieves a pointer to the next element stored in hmmodlib.
Retrieves a pointer to a node.
Retrieves the pointer to a node.
Retrieves the pointer to a node if it exists.
Retrieves a pointer to the first node stored in hmmodlib.
Retrieves a pointer to the next node stored in hmmodlib.
ON THIS PAGE
ON THIS PAGE
