HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  2. HyperWorks Reference Guides
  3. HyperMesh
  4. FE Input Readers
  5. Commands and Functions
  6. hmreslib Functions
  • What's New
  • Get Started
  • Tutorials
  • Manage Files and Data
  • Display Controls
  • Session Navigation
  • Publish Sessions
  • Parameterize Report Templates
  • Workflow Automation
  • HyperWorks Collaboration Tools
  • HyperWorks Reference Guides
Index
HyperWorks Desktop
2022
HyperWorks Desktop
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
    • Extensions
    • External Readers and Altair Binary Format
    • Generic ASCII Reader
    • Batch Mode
    • External Resources
    • Tcl/Tk Commands
    • Translators
    • Result Math
    • HyperWorks Record and Playback
    • HyperWorks Report
    • HyperMesh
      • API Programmer's Guides
      • Data Names
      • Ext API
      • FE Input Readers
        • Result Readers
        • hmlib
          hmlib is a library which contains a set of routines to aid you in writing a C program.
        • hminlib
          hminlib is a set of routines which allows you to write an external input translator.
        • hmmodlib
          hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
        • hmreslib
        • Create FE Input Readers
        • Commands and Functions
          • hmlib Functions
          • hminlib Functions
          • hmmodlib Functions
          • hmreslib Functions
            • Argument Functions
            • Conversion and Math Functions
            • Data Type Functions
            • Result Record Functions
            • Simulation Functions
            • Utility Functions
      • HMASCII
      • Scripts
      • Solver Templates
    • MotionView
    • Templex and Math Reference Guide
    • Script and Model Library
View All Altair Simulation Help
HyperWorks Desktop
HyperWorks Desktop
2022
  1. Home
  3. HyperMesh
  4. FE Input Readers
  • What's New
  • Get Started
  • Tutorials
  • Display Controls
  • Publish Sessions
Index
hmreslib Functions
  • Utility Functions
