hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Closes the hmreslib file and frees memory used by hmreslib for temporary files. (You must close other open files.)
Sets the form of the complex number that hmreslib is expecting.
Inquires about which format is currently being used to interpret complex numbers.
Identifies the author of the binary file being translated.
Identifies the format of a machine.
Initializes hmreslib.
Sets the local displacements flag in the database.
Sets the maximum number of simulations.
Opens an input file containing results.
Creates a program header.
Checks to see if the res file has reached the size limit.
Sets the file size limit that a res file is allowed to reach.
Sets the initial name of the res file name.
Allows a user-specified message to be sent before the program is terminated.
Updates the res filename by adding an integer to the filename. This is used to make multiple res files.
Writes a HyperMesh binary database containing the results previously stored in a file in hmreslib.
Writes a simulation to a file.
