HMRES_SetFileSizeLimit()
Sets the file size limit that a res file is allowed to reach.
void HMRES_SetFileSizeLimit(long size)
HyperMesh hmreslib Function
size
The size that the res file is limited to.
For use with HMRES_ResFileSizeLimitReached, HMRES_SetOutputFilename, and HMRES_UpdateToNewOutputFilename. By default, without a call to this function, the res limit is 1.75 GB.
None.
