HMRES_writesimulation()
Writes a simulation to a file.
int HMRES_writesimulation(char * filename);
HyperMesh hmreslib Function
filename
The name of the file to which the results are written.
Zero, if successful; otherwise, nonzero.
Use this function to write a simulation.
None.
