HMRES_localdisplacements()
Sets the local displacements flag in the database.
void HMRES_localdisplacements(int local);
HyperMesh hmreslib Function
local
Flag that indicates where the displacements are defined. If set to:
  • 0 - The displacements are assumed to be in the global coordinate system.
  • 1 - The displacements are assumed to be in a local nodal coordinate system.
By default, the database is created as if all of the displacements are defined in the global coordinate system. If this is not the case, this function must be called with local set to 1.
If the local displacement flag is set in a results database, HyperMesh transforms the displacements when the results are processed.
None.
