HMRES_terminate()
Allows a user-specified message to be sent before the program is terminated.
void HMRES_terminate(char * format, char * message);
HyperMesh hmreslib Function
format
A pointer to a string designating the format for a printf statement.
message
A pointer to a string containing a message specified by you. This variable can be set to NULL.
This function calls exit() after printing the message.
None.
