HMRES_UpdateToNewOutputFilename()
Updates the res filename by adding an integer to the filename. This is used to make multiple res files.
void HMRES_UpdateToNewOutputFilename(char *outputfilename)
HyperMesh hmreslib Function
Nothing is returned, but the outputfilename parameter is changed to reflect the new res filename.
None.
