hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Closes the current simulation.
Creates a simulation in the results database.
Determines if the simulation already exists.
Finds a simulation name based on its ID.
Opens a simulation.
ON THIS PAGE
ON THIS PAGE
