hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Adds a complex number displacement to a data type.
Adds a complex value to a data type.
Use to add complex vonmises results to a data type.
Adds a displacement value to the results file of the data type.
Adds a value to the current open data type.
ON THIS PAGE
ON THIS PAGE
