HMRES_complexvonmisesadd()
Use to add complex vonmises results to a data type.
int HMRES_complexvonmisesadd(HM_entityidtype id, double magnitude, double phase, double offset);
HyperMesh hmreslib Function
id
The ID of the node or element.
magnitude
The magnitude component of the complex number.
phase
The phase component of the complex number in degrees.
offset
The offset applied to the sine wave.
Use to add complex vonmises results to a data type. hmreslib stores complex results in polar format (magnitude/phase). This presents a problem, as vonmises stress cannot be represented as a complex number. Instead, hmreslib stores vonmises stress squared. This requires that a complex number and an offset be written to the results file.
To calculate the correct values for the magnitude, phase, and offset, a three point method can be used. First obtain the square of vonmises stress at a base angle of 0, 45, and 180 degrees. After these three values are found, the following equations provide the correct magnitude, phase, and offset:
VM1, VM2, and VM3 are the three points where vonmises squared is evaluated at 0, 45, and 90 degrees respectively.
alpha = 2*VM2-VM1-VM3
beta = VM3-VM1
gamma = VM1+VM3
offset = gamma/2.0
magnitude = 0.5*sqrt(alpha*alpha+beta*beta)
phase = 180.0*atan2(beta,alpha)/PI
None.
