HMRES_writeresults()
Writes a HyperMesh binary database containing the results previously stored in a file in hmreslib.
int HMRES_writeresults(char * filename);
HyperMesh hmreslib Function
filename
The name of the file that should be created.
Zero, if successful; otherwise, nonzero.
This function overwrites the file if it already exists.
None.
