HMRES_programheader()
Creates a program header.
void HMRES_programheader(char * title, char * version, char * subtitle, int rightjustify);
HyperMesh hmreslib Function
title
The title of the translator. Appended to the title is the phrase, "to HyperMesh Binary Results."
version
The version of the user translator.
subtitle
The subtitle of the translator.
rightjustify
Variable that determines the title justification. You should assign a value of:
1 - If a right-justified title is desired.
0 - If a left-justified title is desired
None.
