HMRES_getcomplexnumbersform()
Inquires about which format is currently being used to interpret complex numbers.
int HMRES_getcomplexnumbersform(void);
HyperMesh hmreslib Function
0, if the current format is magnitude/phase.
1, if the current format is real/imaginary.
None.
