Load Files
Loads results, user profiles, preferences, solver template files or the Metadata Table.
  1. Load a file in the following ways:
    Note:
    Options may be disabled, depending on the application you are using.
    • From the menu bar, select File > Load > <file type>.
    • From the Standard toolbar, click the drop-down next to the Load icon and select a file type from the list.
  2. Select file to load.
    If you are loading a Do this
    Result file / solver template In the Open dialog, navigate to your working directory and open the file to load.
    Preference file In the Preferences dialog, select the registered preference and click Load.
    Metadata table
    1. In the Meta Data dialog, Select XML file field, navigate to your working directory and open the file that contains metadata.
      File and curve metadata information is displayed.
    2. Copy and paste Templex statements for the tagged information into supported entities. These entities include notes, axes, page titles, and window headers/footers for use in a HyperWorks Desktop session.
    3. Click Close.
The current file is cleared from the memory, and the new file opens.
Metadata Table
Use the Metadata Table to access, review and use metadata information that is read from a file.
Metadata is information that describes the contents and context of the file.
From the Metadata Table, you can access the file's metadata and copy and paste Templex statements for the tagged information into supported entities. These entities include notes, axes, page titles, and window headers/footers for use in a HyperWorks Desktop session.
Supported file types include:
  • .xml files
  • ADAMS files with .xml information in the header
