Import Templates
Templates can be imported by means of the File > Import menu, or by means of the Import toolbar icon .
Templates can be created to read ASCII files that are formatted differently, thus supporting import of multiple file formats. The templates are stored in the <install_directory>/io/model_readers/feinput/. Each template works on only one specific format file. To read in metadata, the required headings must be added to the template requests and record blocks. You may wish to examine an example simple file format template.
Connector templates are registered in the spotweld.cfg file under the same directory. For custom templates, a spotweld_format directory must exist in the same location as the master weld file. The spotweld.cfg file must contain only the names of all the registered weld templates. You can also see an example of a master weld file import template.
HyperGraph and HyperStudy Example
An example of an import template used with HyperGraph or HyperStudy is shown here.
// HWVERSION_8.0-100_Dec 1 2006_5
// (c) 2006 - Altair Engineering, Inc.  All rights reserved.
// Contains trade secrets of ALTAIR Engineering, INC.
// Copyright notice does not imply publication.
// Copyright (c) 2000 - 2002, Altair Engineering, Inc. All rights reserved.
// Decompilation or disassembly of this software is strictly prohibited.
// Excel column "Subcase" template
header
    set mark
    type "Boeing Data"
    set numrecords= count("Subcase", "END")
    set numrequests = 1
    set numcomponents = 7
record
        read null
        readln request
request
do numcomponents
read component
Master Weld File Format
An example for a specific master weld file format is shown here.
# Index::T::X::Y::Z::EID1:: EID2:: EID3::
 1:: 3:: 48.4375:: 9.375  :: 2.0 :: 3:: 2:: 1::
Weld Template
int num
header
    type "CONNECTORS"
    set mark
    find "[0-9]+::"
    rewind
    set num = 0
    if
        do 1000000
            if { isdigit } then { set num = sum(num, 1) }
            readln null
    set numrecords = num
    set numrequests = 9
    requests "ID/T/X/Y/Z/EID1/EID2/EID3/EID4"
    set numcomponents = 1
    components "Value"
record
    read request // ID
    qfind "::"
    set mark
    read request  //T
    rewind
    read num
    qfind "::"
    read request // X
    qfind "::"
    read request // Y
    qfind "::"
    read request // Z
    do num
        qfind "::"
        read request // EID
    set num = diff(4, num)
    do num
        read constant 0 // fake EID
    readln null
