Create New Files
Create a new FE model, session, plot, table, media file, or document file.
Create new file in the following ways:
Note:
Options may be disabled, depending on the application you are using.
  • From the menu bar, click File > New > <file type>.
  • From the Standard toolbar, click the drop-down next to the New icon and select a file type from the list.
The current file is cleared from the memory, and the new file opens.
