*createmarkpanel()
Allows you to interactively select entities from a command file.
*createmarkpanel (entity type mark id message)
HyperMesh Utility Menu Command
entity type
The type of entities to be placed into the mark.
mark id
The ID of the mark being created (1 or 2).
message
The message to display to the user.
To place the selected elements on mark 1:
*createmarkpanel(elements,1,"Select the elements")
