*endmacro()
Ends the definition of a macro started with *beginmacro.
*endmacro ()
HyperMesh Utility Menu Command
The functionality of the HyperMesh Tcl Modify Command commands are available through Tcl. Additionally, commands that allow you to extract information from the HyperWorks Desktop database, such as entity ID numbers on a mark, a list of assemblies, component names, elements per component, nodes per element, node values, and so forth. These are known as HyperMesh Tcl Query Command commands. They are used to query information from the database or template system.
Documentation on the commands that control the Utility menu.
Starts the definition of a Utility menu macro.
Calls a macro from inside a macro.
Adds a button to the Utility menu.
Adds a button group to the Utility menu.
Allows you to interactively select a single entity from a command file.
Allows you to interactively select a list of entities from a command file.
Place the entities from the last operation onto the mark.
Allows you to interactively select entities from a command file.
Adds text to the Utility menu.
Specifies the HyperMesh panel to display on the menu.
Include the contents of the passed macro file.
Read in the next macro file from the history stack.
Read in the previous macro file from the history stack.
Push a filename onto the macro file history stack.
Sets the default selection for a Utility menu button group.
Sets the current displayed page number of the Utility menu.
Sets the color for the Utility menu button group's current selection indicator.
*endmacro ()
