abfOpenComponentByIndex()
Opens an existing component in the currently open request.
intabfOpenComponentByIndex(int idx);
idx
The name of the component to be opened.
Return Value
0
On success
1
On failure (indicates component does not exist)
int ret;
ret = abfOpenComponent("X");
if (ret)
	abfNewComponent("X"):
This function must be called after a request has been opened.
Only one component can be open at a time.
Indexes are zero-based.
