abfSetComponentBuffer()
Transfers an entire range of values.
voidabfSetComponentBuffer(void *ptr, int length);
ptr
A pointer to an array of binary values.
length
The number of values in the area.
Return Value
None
Setting the component buffer deletes any values previously added to the component. The memory pointed to becomes the property of the abf library and must not be freed or used again by the calling routine.
