rpti::item::module
Create or modify report modules.
rpti::item::module create
- Syntax
- Example
rpti::item::module create -config "HwLoop"- Supported Property Names
- To set loop results properties, use the following:
- name
- Name
- Value
- String
- hw_page Model
- Model
- Value
- Page 1/Window 2
- Page window source
- comp_ids
- Components
- Value
- list of component ids
- group_ids
- Sets
- Value
- list of set ids
- add_displayed
- Add displayed components
- lcase_options
- Load Cases
- Value
- Active, Last and Multiple
- lcase_datalist
- Selected Load Cases
- Value
- {simulationid subcasid}
- {1 0}
- exclude_hide_etype
- Entity Type
- Value
- Sets and Components
- Entity type for exclude and hide option
- mask_set_ids
- Enity Selection (Set)
- Value
- Set Ids
- mask_comp_ids
- Enity Selection (Components)
- Value
- Component Ids
- exclude_etype
- Entity Type
- Value
- ignore_element_set_ids
- Entity Selection(Set)
- Value
- Set Ids
- ignore_component_ids
- Entity Selection(Component)
- Value
- Component Ids
- ignore_num_layers
- Number of Layers
- Value
- Integer
- loop_start
- Start loop with
- Value
- Component and loadcase
- add_complete_overview
- Overview for each loadcase
- Value
- 0 or 1
- Enable overview for each loadcase
- exportopt
- Export
- Value
- All, Above, Below, EqualTo and Overview
- expcriteria
- Export
- Value
- real number
- Export Criteria Value
- loop_over_hotspots
- Loop Over Hotsport
- Value
- 0 or 1
- Enable loop over hot spots
- split_table
- Auto Split Table
- Value
- 0 or 1
- split_table_type
- Split table by columns or rows
- Value
- Columns or Rows
- Auto split table by row or column
- split_rows
- Maximum Rows
- Value
- Integer
- split_cols
- Maximum Columns
- Value
- Integer
