rpti::item validate
Evaluates registered validate callback.
- Syntax
rpti::item validate
- Parameters
- -id
- Value: Item ID. Returns -1 if errors, 0 if warnings, and 1 if passed.
Report APIs for Altair applications that use Tcl as a scripting language.
Enables you to execute and export report.
Add, access or modify report items.
Interact with items of type break.
Interact with items of type chapter. This item type is valid only for document reports.
Interact with items of type exceldocument.
Interact with items of type externalobject.
Interact with items of type image.
Interact with items of type property.
Interact with items of type slide. This item type is valid only for presentation reports.
Interact with items of type table.
Interact with items of type tableofreference.
Interact with items of type text.
Interact with items of type textdocument.
Interact with items of type worddocument.
Create or modify report modules.
For better performance data created, manipulated or deleted go into a cache.
Clone an Item.
Deletes the item with the specified ID.
Queries the value of one property or role or attribute.
Check if an item attribute, property or role exists.
Sets one or multiple parameters to specified values.
Insert an item to a parent.
Check if the item is a leaf.
Check if the item with the specified ID is valid.
Load items properties defined in configuration xml.
Notifies all registered views to redraw itself.
Remove an item from parent.
Reparents an object that already has a parent.
Report APIs for Altair applications that use Python as a scripting language.
rpti::item validate© 2022 Altair Engineering, Inc. All Rights Reserved.
