This law is similar to the Johnson-Cook plasticity model. The same parameters are used
to define the work hardening curve.
However, the equation that describes stress during plastic deformation is:
(1)
Where,
- Stress (Elastic + Plastic Components)
- Plastic strain
- Temperature (computed as in Johnson-Cook plasticity)
- Yield stress
- Hardening exponent
- Strain rate, must be 1 s-1 converted into user's time unit
- Reference strain rate
Additional inputs are:
- Maximum flow stress
- Plastic strain at rupture
The
enables to define element rupture as in the former law. The
theoretical aspects related to strain rate computation and filtering are also the same.
