/ARCH (Obsolete)
Block Format Keyword Describes the architecture flag.
/ARCH
Mach1 Mach2 Mach3 Mach4 Mach5 Mach6 Mach7 Mach8
Mach1 Optimization and platform flag.
= 0 (Default)
Built-in platform: platform of the running Starter.
= 1
Generic platform: restart file compatible with any Radioss Engine.
= n
Radioss platform identifier: Radioss platform number.
(Integer)
Mach2,..., Mach8 Architecture compatibility flag.
= 0 (Default)
No specific platform.
= 1
Generic platform.
= n
Radioss platform identifier.
(Integer)
Radioss Platform Number
Platform ID Number
Platform Name
2
CRAY T90, T90-IEEE
3
SGI65
4
HP11 PA-RISC
5
IBM Power 4
6
HP Alpha
7
Fujitsu VPP 5000
8
NEC SX6
9
Linux IA32
10
Linux IA64
11
HP11 IA64
12
Linux X86-64
13
Fujitsu Primepower
14
CRAY X1
15
Sun Sparc
16
Windows IA32
17
Linux Alpha
  1. It is required that the parallelism type be identical between Starter and Engine (for example, SPMD Starter and SPMD Engine executables).
    Above is a list of the actual platforms. New platforms will be added when available.
  2. For performance point of view, it is recommended to set only one platform, which corresponds to the Radioss Engine machine. Using generic platform or setting more than one platform may decreases performance of Radioss Engine.
