/FAIL/XFEM_JOHNS (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
| /FAIL/XFEM_JOHNS/mat_ID/unit_ID | |||||||||
| D1 | D2 | D3 | D4 | D5 | |||||
| Ifail_sh | |||||||||
Optional Line
| fail_ID | |||||||||
| mat_ID | Material
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| D1 | 1st
parameter (Real) |
| D2 | 2nd
parameter (Real) |
| D3 | 3rd
parameter (Real) |
| D4 | 4th
parameter (Real) |
| D5 | 5th
parameter (Real) |
| Reference strain
rate (Real) |
| Ifail_sh | Shell failure flag
(Integer) |
| fail_ID | (Optional) Failure
criteria identifier 4 (Integer, maximum 10 digits) |
Example (Steel)
#RADIOSS STARTER
/UNIT/1
unit for mat
# MUNIT LUNIT TUNIT
Mg mm s
#- 1. MATERIALS:
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9
# E Nu
210000 .3
# a b n EPS_p_max SIG_max0
270 450 .6 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/FAIL/JOHNSON/1/1
# D1 D2 D3 D4 D5
0.11 0.08 -1.5 0 0
# EPS_0 Ifail_sh Ifail_so Dadv Ixfem
1 1 1 0.5 1
#enddata
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|---10----|Comments
- This failure model is available for Shell only.
- The parameters are
used in the stress-strain relationship:
(1) Where,
T* is computed in the material law, if this one is thermo plastic, like /MAT/LAW4 (HYD_JCOOK).
- Current known
limitations are:
- /PARITH/ON does not ensure results repeatability, if SPMD > 1; it works in SMP parallel mode only.
- XFEM is currently NOT compatible with either /ANIM/VECT or with /PARITH/OFF.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
