/DFS/DETLINE
Block Format Keyword Enable explosive material ignition from a detonation line [A,B].
/DFS/DETLINE/detline_ID/unit_ID | |||||||||
XA | YA | ZA | |||||||
XB | YB | ZB | |||||||
TDET | mat_IDDET |
detline_ID | Detonation line identifier (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
XA | Point A - X
coordinate Default = 0.0 (Real) |
YA | Point A - Y
ZA | Point A - Z
XB | Point B - X
YB | Point B - Y
ZB | Point B - Z
TDET | Detonation time Default = 0.0 (Real) |
mat_IDDET | Explosive material number
concerned by detonation time.
(Integer) |
- It is possible to define multiple detonation lines.
- If a detonation time is not defined, /MAT/LAW5 (JWL) material law will instantaneously detonate.
- Detonation times are available in the Starter output file (IPRI ≥ 3).
- Burn fractions are available in time history file with /TH/BRIC card and BFRAC keyword.
- Detonation velocity is taken from JWL material law.
