/DFS/WAV_SHA
Block Format Keyword Enables to shape detonation wave to take into account obstacles.
/DFS/WAV_SHA/detline_ID/unit_ID | |||||||||
XDET | YDET | ZDET | TDET | mat_IDDET | grnod_ID |
detline_ID | Detonation Line identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
XDET | X coordinate. (Real) |
YDET | Y coordinate. (Real) |
ZDET | Z coordinate. (Real) |
TDET | Detonation time. Default = 0.0 (Real) |
mat_IDDET | Explosive material number concerned by
detonation time.
(Integer) |
grnod_ID | Unsortable node group identifier. 1
2 Default = 0 (Integer) |
- Node path must be provided in the correct order through an unsortable node group identifier (/GRNOD/NODENS), which is mandatory.
- Detonation times are available in the Starter output file (IPRI ≥ 3).
- Burn fractions are available in the time history file with /TH/BRIC card and BFRAC keyword.
- Detonation velocity is taken from the /MAT/LAW5 (JWL).
- Only compatible with 2D modeling.
