/GRNOD/NODENS
Block Format Keyword Describes the unsortable node groups by list of nodes.
| /GRNOD/NODENS/grnd_ID/unit_ID | |||||||||
| grnd_title | |||||||||
| node_ID1 | node_ID2 | node_ID3 | node_ID4 | node_ID5 | node_ID6 | node_ID7 | node_ID8 | node_ID9 | node_ID10 |
| grnd_ID | Node group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grnd_title | Node group
| node_ID1, node_ID2..., node_ID10 | List of secondary node
identifiers (Integer) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- Nodes are not sorted by Radioss, they retain the order entered. This option is only needed in interface TYPE8 and /XELEM.
