Surfaces
Block Format Keyword
Input Type Keywords
Keyword
Input Type
/SURF/SEG
Segments
/SURF/SUBSET
Shell subsets
/SURF/SUBMODEL
Submodel
/SURF/PART
Shell parts
/SURF/ELLIPS
Group of 3D elements
/SURF/GRSHEL
Group of shells
/SURF/GRSH3N
Group of 3-node shells
/SURF/MAT
Shell material
/SURF/PROP
Shell property
/SURF/SURF or /SURF/DSURF
Surfaces
/SURF/BOX or /SURF/BOX2
Box
Geometrical Surfaces
Keyword
Input Type
/SURF/ELLIPS
Hyper-ellipsoid
/SURF/PLANE
Infinite plane
  1. A surface is a set of 3-node or 4-node segments. It can be defined:
    • explicitly, with segment connectivity
    • by box
    • by subsets or parts (all 3-node and 4-node shells belonging to these entities are used to define the surface)
    • by submodels (all 3-node and 4-node shells belonging to parts in the listed submodels are used to define the surface)
    • by properties or materials (all 3-node and 4-node shells belonging to these entities are used to define the surface)
    • by shell groups
    • with other surfaces
  2. All nodes must belong to a shell element, a brick element or a triangular shell element.
  3. A surface cannot be defined using Madymo surfaces.
