/SURF/ELLIPS
Block Format Keyword Describes the hyper-ellipsoid surface definition.
/SURF/ELLIPS/surf_ID/unit_ID | |||||||||
surf_title | |||||||||
skew_ID | n | ||||||||
Xc | Yc | Zc | |||||||
a | b | c |
surf_ID | Surface
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
surf_title | Surface
title. (Character, maximum 100 characters) |
skew_ID | Skew identifier defining
the initial orientation of the surface. (Integer) |
n | Degree of the
hyper-ellipsoid. Must be greater than or equal to 2. Default = 2 (Integer) |
Xc | Center
coordinate. (Real) |
Yc | Center
Zc | Center
a | Semi-axis
length. (Real) |
b | Semi-axis
length. (Real) |
c | Semi-axis
length. (Real) |
- The equation of the
hyper-ellopsoid is:
(1) - The Sphere is the
case.
Where, n=2 and a=b=c=r.
