/GRNOD/GEN_INCR
Block Format Keyword Generates a group of nodes by listing the first and last node IDs in the range with a user-defined increment value.
| /GRNOD/GEN_INCR/grnd_ID/unit_ID | |||||||||
| grnd_title | |||||||||
| first_ID | last_ID | Incr | |||||||
| grnd_ID | Node group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grnd_title | Node group
| first_ID | First node identifier in
the list. (Integer) |
| last_ID | Last node identifier in
| Incr | Increment value of the
list generation from first_ID to
last_ID. Default = 1 (Integer) |
- Node groups are used to define secondary nodes of rigid walls, interfaces, rigid bodies or nodes to which a load is applied, like a concentrated load or a fixed velocity.
- The group includes first_ID, first_ID+Incr, first_ID+2*Incr, first_ID+3*Incr, … continuing through last_ID.
- Multiple first_ID, last_ID, and Incr lines can be defined in one block.
