/INIMAP2D/FILE
Block Format Keyword Map 2D velocity and thermodynamic values into a 3D axi-symmetric space for use with /ALE/EULER materials.
/INIMAP2D/FILE/inimap2d_ID | |||||||||
inimap2d_title | |||||||||
node_ID1 | node_ID2 | node_ID3 | |||||||
grbric_ID | grquad_ID | grtria_ID | |||||||
Filename |
inimap2d_ID | Inimap2d block identifier. (Integer, maximum 10 digits) |
inimap2d_title | Inimap2d block title. (Character, maximum 100 characters) |
node_ID1 | Node 1 identifier. (Integer, maximum 10 digits) |
node_ID2 | Node 2 identifier. (Integer, maximum 10 digits) |
node_ID3 | Node 3 identifier. (Integer, maximum 10 digits) |
grbric_ID | Brick group on which initialization is
performed. (Integer) |
grquad_ID | Quad group on which initialization is
grtria_ID | Tria group on which initialization is performed. (Integer) |
Filename | File generated by previous 2D axi-symmetrical run
with /STATE/INIMAP2D/FILE. (Character) |
- node_ID1, node_ID2 and node_ID3 define the local coordinate system used for mapping.
2D Original Model 3D Target Model Note: The coordinate system ( , , ) does not have to be orthogonal, as an orthonormalization of the vector is performed during the Starter. - If explosive material LAW5 (JWL) is used as submaterial, then mapping will be proceeded considering all explosive was burnt (burn fraction = 1.0). The mapping will be done with detonation products only with a burn fraction = 1.0.
